TS5828 heat issue
i've seen threads talking about the heat issue of it, and seems like giving it a heat shrink is a good idea
However I'm thinking if I supply the lowest voltage it can take, will the heat issue be reduced with same output power?
it gets really hot when i give 12V to it Confused
Oscar has an article on reducing heat on this VTx here: https://oscarliang.com/fix-overheat-issu...ansmitter/
Any video transmitter can get hot, it's a normal behavior, just make sure you don't power it on too long sitting on the ground. With good airflow during flight it should be fine.
Heat shrink doesn't help with overheating, i guess you mean heat sink. Yes it might help reduce the heat.
Also feeding VTX can help too since it reduce the heat from voltage regulator.
see my post: https://oscarliang.com/fix-overheat-issu...ansmitter/
I had used the same vtx for a while and was worried about the heat but in flight with airflow makes a huge difference to cooling, the vtx lasted me a good while too
Information
Using a FLIR or temp ir cam, Has anyone ever posted pics of the heat in a transmitter like the ts5828 in its first 2 minutes. It seems after 4 years the ts5828 still can overheat and shuts down after 3 minutes.
I have 4 of them and 1 shuts down. the others get too hot to touch.
  FPV noise issue demvlad 11 766 15-May-2023, 10:51 AM
  Help Is this a FC issue? (Video) Zheroz00 3 381 18-Apr-2023, 04:10 PM
  Help Video sync / format issue? Opatry 12 1,717 14-Nov-2022, 01:22 PM
  Help Cobra X V1 | double image issue and video feed feeling weird/stuttering OverSavior 6 951 24-Aug-2022, 11:24 AM
Last Post: OverSavior
  Help RDQ Mach 3.1 VTX SmartAudio issue BSOD 12 1,086 06-Jun-2022, 07:16 AM
Last Post: kafie1980
