08-Sep-2021, 07:00 PM
I now have a few flight controllers that seem to have bad gyros, and I'm trying to figure out if there is anything I can do to repair them. One is on a Flywoo F411 16x16 FC, and the other is on an original FPVCycle Zeez 1S AIO. On the Zeez board, as soon as power is applied, the gyro shows the quad rotating around the Z (yaw) axis by a few degrees a second. On the Flywoo board, it seems to be temperature dependent as the gyro signal is initially stable then after a short while begins showing rotation around multiple axis, again at a few degrees per second.
Both use MPU6000 gyros. I have checked this pins for anything that could be touching and tried reflowing the joints without any improvement.
Any ideas? Do gyros just go bad after awhile?
