I have a Mobula 6 Tinywhoop and a Jumper T Pro multiprotocol remote control with an external AIO ELRS module.
The ELRS module is set to 100 mW and 500Hz (I'm not sure what this means). On the Jumper T, I've set the "External RF" to "CRFS".
Settings on AIO ELRS module:
- ExpressLRS - Version: 2.5.1
- ExpressLRS TX expressLRS: 10.0.0.1
- Packet rate: 500 Hz
- TX power: 100 mW
- Telem ratio: 1:64 TLM
I don't think I'm doing anything wrong with the remote control, but the Mobula won't go into binding mode.
When I connect the battery, then disconnect, connect a second time, disconnect, and connect a third time, the drone should enter binding mode. This would be confirmed by a 2x green flash per second. However, the green LED on my drone only flashes once per second. The binding mode has not been reached.
An internet source https://brushlesswhoop.com/spi-bind-via-betaflight/ indicates that it is also possible to put the drone into binding mode via BetaFlight, but I don't have this button in my BetaFlight.
My BetaFlight never showed me the "Bind Receiver" button. I tried this with 3 different drones.
This is the receiver configuration:
This is my BetaFlight and Board version:
This is the CLI tab showing "status":
I tried tried to follow this tutorial:
but CLI command line doesn't accept setting a binding phrase
- TX power: 100 mW
