tribus 117mm 3" micro
Wanted to build a lightweight 3" to compare to a typical 1407 build so designed a new lightweight and compact frame
Using old rcx 1304 5000kv which are still superb motors considering how old they are now and at only £28/$36 a set delivered I couldn't resist.
These motors are about on par performance and weight with the new emax rs1106 4500kv but nearly half the price
Also found some new tiny esc's from HGLRC, only 0.8g each and 13a rated for 2-3s which are performing great so far, although i prefer the cleanliness of a 4in1 I hate the reliability and much prefer to replace one esc if needed.
Frame weighs in at only 19.5g for 3mm bottom plate and seems a bit overkill, but nice and reassuringly strong as I have had my friends flying or at least trying to learn to fly with it  ROFL although admittedly its probably a little quick for a beginner quad but virtually no damage can be done to something which weighs so little!
85g dry weight and 130g with 450mah 3s
got some dvr but was preeetty windy!
[-] The following 6 users Like ZERONEST's post:
  • Drone0fPrey, Tom BD Bad, jimbo_wa, unseen, Oscar, kaitylynn
that thing is violent Smile
what's the FC mounting pattern? is it possible to use a Split on it?
  • ZERONEST
(29-Oct-2017, 11:35 PM)Oscar Wrote: that thing is violent Smile
hehe its really enjoyable to fly!
unfortunately not sorry Sad only 20x20 fc mount and at 117mm there's literally just enough space to fit the micro swift
I think the props would be very badly in the image too at low camera angles
[-] The following 1 user Likes ZERONEST's post:
  • kaitylynn
Great Quad! Very well thought out!
The Obsession IS Real!
  • ZERONEST
I might be doing a build for a friend based on this setup. He flies FlySky and I am worried about space. Any thoughts? Im just starting to reseach his options of small Rx's. Also how does a TX03 fit?
(05-Mar-2018, 03:16 AM)Drone0fPrey Wrote: I might be doing a build for a friend based on this setup. He flies FlySky and I am worried about space. Any thoughts? Im just starting to reseach his options of small Rx's. Also how does a TX03 fit?
Cool! It is a tight build no doubt about it! the vtx03 fits fine as that's what I'm using on mine.
https://www.banggood.com/818CH-Mini-Rece...rehouse=CN
a rx of of this size will fit perfectly and maybe even this new "flit10" might just fit too but cannot confirm
https://www.banggood.com/Flit10-2_4G-10C...mds=search
Hope this helps! Thumbs Up Thumbs Up
Thumbs Up Yes it does thank you!
  • ZERONEST
  Help Micro Quad flying easy but wobbling Harry1 46 1,369 13-Feb-2024, 10:18 PM
  AXII 2 Micro 20mm antenna fit in Mob6? dwije21 8 405 27-Aug-2023, 03:30 AM
Last Post: brettbrandon
  Build Micro cine lifter / Scorpion gunship mstc 2 497 09-Aug-2023, 03:57 PM
Last Post: iFly4rotors
  Help Micro reverb parts? truglodite 4 333 02-Aug-2023, 04:44 PM
Last Post: truglodite
  CLI Dump for HGLRC Drashark 1S 1.6inch Micro Quad Oscar 0 560 18-Jun-2023, 08:45 PM
Last Post: Oscar
