Transmitter/Reciever/FC/Motor/Cleanflight problem
I had a working quad, then unfortunately flashed my Naze32 V6 Acro Board with Cleanflight 2.0. I then experienced the following.
1. Motors would not arm (not beeping) when battery or USB from computer is connected to FC.
2. Receiver tab in Cleanflight showed input from Transmitter. (indicating tx is bound to rx)
3. Motors would not spin on input from tx.
4. Motors would not respond in Cleanflight Motor mode.
5. Flashing orange light on Naze board.
I then re-flashed the original version of Cleanflight , that was on my Naze prior to flashing 2.0, onto the board. I experienced the following.
1. Motors armed (beeping confirmed)
2. Motors would not spin with input from tx.
3. Flashing orange light on Naze board
Thinking the FC may be fried, I replaced it with a Naze 32 V Full Board.
I flashed the board with the latest version of Cleanflight 1.9 not wanting to use 2.0. I am experiencing the following.
1. Motors arm. (make expected beeping)
2. Motors not spinning up with input from tx.
Any one have any ideas to solve the the current problem?
I cannot connect to Cleanflight as 2.0 will not operate with 1.9.
I have a Chromebook which automatically updated the Cleanflight app to 2.0 and does not support downloading the 1.9 version.
Thank you for any assistance.
what ESC are you using?
What ESC protocol is used in Cleanflight? Have you tried other protocols in the list? such as Oneshot125 or PWM?
(31-May-2017, 11:51 PM)Oscar Wrote: what ESC are you using?
BH Heli
Oneshot
Not that it matters as I cannot access the version of Cleanflight that would give me the info I needed,  thanks to Chromebook automatically updating the older version, to 2.0.  I will have to go back to flashing 2.0 on the Naze 32 and dealing with that particular set of problems, which were
what brands and model are the ESC's?
here is how you can keep old version of cleanflight: http://intofpv.com/t-keeping-older-versi...leanflight
please try other ESC protocols too
(02-Jun-2017, 12:06 AM)Oscar Wrote: what brands and model are the ESC's?
EMax 12a
I decided to try and flash 2.0 onto my Acro board again. I connected the board and changed to PWM from Oneshot125 and the problems were solved. The only thing I cannot do is calibrate the motors using the Cleanflight motor tab. No big deal as I originally calibrated the motors individually.
yea those EMAX 12A are really old... probably don't have the latest BLHeli installed thus don't support oneshot.
Which emax 12a are those? Latest version had oneshot support added.
I have the same problem.,but motors spinning with cleanflight configurator, but they wont spin by any change from Tx. See the video below to get a clear picture of the issue.after research i have seen a lot of people facing the same issue, i made a video to show others about the issue, please have a look and advice
@baher. You have prearm setup. I would eliminate that for now and see if you can arm. The quad will also not arm when you are connected to the computer. Get rid of prearm. Disconnect from the computer. Arm your quad, and see if the motors spin.
  Help Dji o3 rc link problem. Mad35 20 777 21-Jan-2024, 02:20 PM
Last Post: Mad35
  New Product RadioMaster Boxer Transmitter SnowLeopardFPV 29 5,038 30-Dec-2023, 06:42 PM
Last Post: husafreak
  Problem with FRsky R9 900mhz PJKMBAKER 5 369 24-Dec-2023, 02:18 PM
Last Post: PJKMBAKER
  E8 transmitter Armattan Chameleon frsky binding Ed_FPV 1 185 03-Dec-2023, 04:38 PM
  Zorro external elrs module problem PJKMBAKER 14 798 24-Oct-2023, 08:57 AM
