16-May-2016, 03:31 PM (This post was last modified: 01-Jun-2016, 03:34 PM by fpv-direct.com.)
FPV-Direct.com is pleased to announce the latest addition to our line of mini FPV racers...... Toretto 130 from Furious FPV....
Furious FPV carefully designed this sub-250-gram frame from the ground up to satisfy strict requirements for a speedy, indoor/outdoor compatible, feature-packed mini quadcopter.
Furious-FPV has completely designed a new flight controller PIKO BLX for their Torreto 130 frame because such an amazing quadcopter calls for an equally incredible flight controller. PIKO BLX is currently the smallest STM32 F3 flight controller for mini FPV racers. PIKO BLX is extremely light, develop friendly, and very easy to set up. PIKO BLX FC is equipped with an on-board LC filter and integrated BEC. The PIKO flight controller is also compatible with OSD+GPS+LED+Sonar+Battery Monitoring devices - all can be used at the same time.
More information about the Piko BLX Flight Controller can be found here http://furiousfpv.com/product_info.php?products_id=41
Torreto 130 is the first 130-sized quadcopter that is equipped with super-fast 48MHZ ARM 32-bit ESCs. This ESCs provides extremely fast throttle response, anti-blocking protection, active brake to give you the best controllability that you can get from a 130-sized racer.
Toretto 130 is also equipped with Furious-FPV's uniquely designed Video transmitter with integrated OLED display to display video transmitter channel and battery information.
The frame also comes with a super small FPV transponder for lap counting.
UPDATE 1: Release date will be June 12.
UPDATE 2: Some modifications have been made to the frame
Below are some indoor flight videos. We will update more outdoor flight videos when weather permits.
Video of mr.miyagi.ew flying Toretto 130
https://www.instagram.com/p/BFMTqvpNXG1/
Toretto 130 in Korea
Flight Video from Kyle Stacy
Please ask us questions and follow this thread for more updates regard the Torreto 130 and incoming awesome products in the very near future....
