07-Mar-2016, 01:08 PM
Hey Guys just need an opinion on where to go with my tune. My 6" Alien is flying great, but I was looking at the blackbox log and it looks like I have to much D, would I be able to filter D changing soft_gyro_lpf_hz, set dterm_lpf_hz?
My set up:
ImpulseRC Ailen 6"
lumiere lux flight controller
20 amp Little Bee's esc
2204 2300kv rtfq motors
5x4x3 HQ props
1300 4s lumiere
thanks for looking and any advice
https://www.dropbox.com/s/ord2kss5q724e6y/last.TXT?dl=0
https://dl.dropboxusercontent.com/u/1575...-07%29.MOV
My set up:
ImpulseRC Ailen 6"
5x4x3 HQ props
1300 4s lumiere
# dump
# BetaFlight/LUX_RACE 2.3.4 Jan 28 2016 / 09:46:10 (c2cb02a)
# dump master
mmix 0 1.000 -1.000 0.731 -1.000
mmix 1 1.000 -1.000 -0.731 1.000
mmix 2 1.000 1.000 0.731 1.000
mmix 3 1.000 1.000 -0.731 -1.000
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -CURRENT_METER
feature -ONESHOT125
feature -BLACKBOX
feature VBAT
feature RX_SERIAL
feature FAILSAFE
feature TELEMETRY
feature ONESHOT125
feature BLACKBOX
map AETR1234
serial 1 32 115200 57600 0 115200
serial 2 128 115200 57600 0 115200
led 0 15,15:ES:IA:0
led 1 15,8:E:WF:0
led 2 15,7:E:WF:0
led 3 15,0:NE:IA:0
led 4 8,0:N:F:0
led 5 7,0:N:F:0
led 6 0,0:NW:IA:0
led 7 0,7:W:WF:0
led 8 0,8:W:WF:0
led 9 0,15:SW:IA:0
led 10 7,15:S:WF:0
led 11 8,15:S:WF:0
led 12 7,7:U:WF:0
led 13 8,7:U:WF:0
led 14 7,8:D:WF:0
led 15 8,8:D:WF:0
led 16 8,9::R:3
led 17 9,10::R:3
led 18 10,11::R:3
led 19 10,12::R:3
led 20 9,13::R:3
led 21 8,14::R:3
led 22 7,14::R:3
led 23 6,13::R:3
led 24 5,12::R:3
led 25 5,11::R:3
led 26 6,10::R:3
led 27 7,9::R:3
led 28 0,0:::0
led 29 0,0:::0
led 30 0,0:::0
led 31 0,0:::0
# color
set emf_avoidance = OFF
set min_check = 1100
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 30
set rssi_ppm_invert = OFF
set rc_smoothing = OFF
set min_throttle = 1080
set max_throttle = 1850
set servo_center_pulse = 1500
set enable_fast_pwm = OFF
set motor_pwm_rate = 400
set servo_pwm_rate = 50
set disarm_kill_switch = ON
set small_angle = 25
set fixedwing_althold_dir = 1
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set serialrx_provider = SBUS
set spektrum_sat_bind = 0
set telemetry_switch = OFF
set telemetry_inversion = ON
set frsky_default_lattitude = 0.000
set frsky_default_longitude = 0.000
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set battery_capacity = 0
set vbat_scale = 110
set vbat_warning_cell_voltage = 36
set current_meter_scale = 400
set current_meter_offset = 0
set current_meter_type = ADC
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_yaw = 0
set gyro_lpf = 188HZ
set moron_threshold = 32
set yaw_control_direction = 1
set yaw_motor_direction = 1
set tri_unarmed_servo = ON
set servo_lowpass_freq = 400
set failsafe_delay = 10
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set acc_hardware = 0
set baro_hardware = 1
set mag_hardware = 1
set blackbox_rate_num = 1
set blackbox_rate_denom = 4
set blackbox_device = SERIAL
set beeper_off_flags = 0
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
# rxfail
rxfail 3 a
rxfail 5 h
# dump profile
# profile
profile 1
aux 0 0 2 1475 2100
aux 1 27 2 1775 2100
aux 2 25 0 1400 2100
aux 3 0 0 900 900
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
adjrange 0 0 3 1350 1725 6 1
adjrange 1 0 3 1850 2075 8 1
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# servo
set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
set gps_wp_radius = 200
set nav_controls_heading = ON
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set gtune_loP_rll = 10
set gtune_loP_ptch = 10
set gtune_loP_yw = 10
set gtune_hiP_rll = 100
set gtune_hiP_ptch = 100
set gtune_hiP_yw = 100
set gtune_pwr = 0
set gtune_settle_time = 450
set gtune_average_cycles = 16
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 0
set yaw_deadband = 0
set default_rate_profile = 1
set gimbal_mode = NORMAL
set acc_lpf_hz = 20
set accxy_deadband = 40
set accz_deadband = 40
set accz_lpf_cutoff = 5.000
set acc_unarmedcal = ON
set acc_trim_pitch = 0
set acc_trim_roll = 0
set baro_tab_size = 21
set baro_noise_lpf = 0.600
set baro_cf_vel = 0.985
set baro_cf_alt = 0.965
set mag_declination = 0
set delta_from_gyro = ON
set pid_controller = MWREWRITE
set p_pitch = 36
set i_pitch = 40
set d_pitch = 22
set p_roll = 36
set i_roll = 40
set d_roll = 22
set p_yaw = 100
set i_yaw = 50
set d_yaw = 5
set p_pitchf = 1.500
set i_pitchf = 0.400
set d_pitchf = 0.010
set p_rollf = 1.100
set i_rollf = 0.400
set d_rollf = 0.010
set p_yawf = 4.000
set i_yawf = 0.400
set d_yawf = 0.000
set level_horizon = 6.000
set level_angle = 6.000
set sensitivity_horizon = 75
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 55
set i_level = 55
set d_level = 100
set p_vel = 120
set i_vel = 45
set d_vel = 1
set soft_gyro_lpf_hz = 60
set dterm_lpf_hz = 0
set acro_plus_factor = 0
# dump rates
# rateprofile
rateprofile 1
set rc_rate = 100
set rc_expo = 70
set rc_yaw_expo = 36
set thr_mid = 50
set thr_expo = 0
set roll_rate = 65
set pitch_rate = 50
set yaw_rate = 100
set tpa_rate = 0
set tpa_breakpoint = 1500
