Tinyhawk 2 broken FC
The FC is broken. When I plug in a lipo it doesn't do anything anymore If I connect it to my PC on USB it works fine. I can also see it in betaflight
I have a picture to show what is wrong. Who knows what component it is I thought is an inductor. photo is what I see now. Who can help me.
Ps: how can i add photos.
Foto
https://intofpv.com/attachment.php?aid=4271
The component that your arrow is pointing to is an inductor as you stated. Those still work perfectly fine even when the ceramic casing is chipped like on yours which is quite common, so that inductor isn't the cause of your problem.
An FC booting up from a USB cable but not from a LiPo means that the 5V regulator on the FC is fried. When plugging in via a LiPo the LiPo voltage is then regulated up or down to 5V via an onboard 5V regulator, but when you plug a USB cable in the 5V regulator is bypassed because the USB provides 5V to the FC instead.
You have one of the following 3 options:
  1. Locate and replace the 5V regulator on the FC circuit board.
  2. Power the FC by injecting 5V into one of the 5V pads using an external 5V BEC.
  3. Replace the FC with a new one.
thank you for the quick response this is what i was looking for
https://intofpv.com/t-resurrecting-dead-emax-tinyhawks
In case ur interested
  Need help fixing broken AIO FC - identifying SMD romangpro 17 1,554 04-Apr-2023, 05:36 PM
Last Post: romangpro
  Tinyhawk 3 no secondary beeps LDR_R4ndom 11 498 15-Nov-2022, 06:00 AM
Last Post: LDR_R4ndom
  FC broken? Smokie 6 648 21-Oct-2020, 05:50 PM
Last Post: Smokie
  Broken Connector on Brand New HolyBro F7 HDV Flight Controller donwie63 6 593 16-Oct-2020, 03:56 AM
Last Post: voodoo614
  Flight controller broken Smoses221 3 2,275 20-Oct-2019, 01:06 AM
