"Throttle Stick" & Twitchy motors?
(30-Sep-2017, 03:48 PM)Justbenh Wrote: As soon as the weather clears here I'll be sure to get one - are there any settings besides blackbox I need to enable to get the log? Also, how do I open it? I've seen on google it saves as a .BBL file?
You need to install the Blackbox Explorer which is also available on the Chrome app store. As long as you enable the black box feature, you'll be able to record. However, your flight controller doesn't have much memory for black box logging, so it's probably a good idea to assign a switch to activate black box logging in the Modes tab. Then you can activate it when you need to.
Before you go out to record a log, make sure you've cleared the black box memory first!
  Left Throttle not controlling Drone soky157 7 99 23-Apr-2024, 08:21 PM
Last Post: soky157
  Motors not responding to transmitter input(no airmode) corwin 1 43 22-Apr-2024, 05:07 PM
  Beta95x V3 motors not start kronk 3 102 20-Apr-2024, 07:28 PM
Last Post: kronk
  Express LRS connects but no stick movement AMMistry18 28 677 15-Apr-2024, 06:28 AM
Last Post: AMMistry18
  BFC REORDER MOTORS NOT SPINNING soky157 4 92 08-Apr-2024, 05:38 AM
