Throttle Expo and Throttle mid
About throttle expo and throttle mid (in cleanflight)
if i want my quad to hover at 50% (center of the throttle stick), should i raise throttle expo and drop throttle mid?
Because default on betaflight is throttle mid 50 and expo 0 and my quad hovers at about 30% (roughly 1 meter off the ground)..
The thing is that i want better resolution and softer throttle response.
Any thoughts on this?
If you are hovering at around 30%, then you want to bring your throttle mid down. I like really soft throttle feel at low end throttle to make it easier to maintain low altitude flying. I match my throttle mid with my hover point on the throttle. 40% throttle for steady hover = 40 throttle mid. Try 35 for your throttle mid and set expo to your desired feel for throttle response (I keep mine at 70).
Oscar explained this before here: http://blog.oscarliang.net/rc-roll-pitch...eanflight/
Thanks.. but i had to drop my throttle mid all the way down to 5 and my expo to 60 and now it hover around 40%.. thats strange
Update: just realized I had expo setup on my TX as well, cleared it it's working as expected now
Guys, where is better to set expos - on quad's brain or on the TX ? And why?
(12-Apr-2016, 10:54 AM)E.L.K. Wrote: Guys, where is better to set expos - on quad's brain or on the TX ? And why?
I personally would use no curve or expo on the TX, so you have max resolution on the sticks.. Expo only on FC
  Solved Quad gets shaky and loud over 30% throttle. Suros 10 439 23-Nov-2022, 10:37 PM
Last Post: Suros
  Throttle Range In Custom Setup DragonTheta 1 318 20-Apr-2022, 08:57 PM
Last Post: kafie1980
  Component failure mid flight, Rob Axel 6 510 24-Jul-2021, 12:26 AM
Last Post: MrSolo
  Help Brushless motor or ESC broken? Not working properly after full throttle Niujaus 5 8,188 30-Apr-2019, 12:27 PM
Last Post: Drone0fPrey
  Drift on throttle release after punch-out: Tuning Issue? (Diatone GT-M3) x91qLt7 15 5,547 08-Jun-2018, 04:17 AM
Last Post: x91qLt7
