09-Dec-2023, 09:06 PM
For my new build with O3 I bought
Hobbywing XRotor 65A ESC.
After everything was assembled I immediately put my attention that
there were not any beeps from the motors. However ESC gave power to FC.
Checking motors spin in Betaflight gave no result.
Checking ESC in BLHeliSuite32 - no interface was found, so I couldn't reflash it.
I tried to revive (reflash) via arduino nano - no avail.
I had Mamba ESC. Replaced dead Hobbywing XRotor 65A ESC with Mamba - everything is OK.
Recently, I bought a Holybro Kakute H7 V1.3 Stack with Tekko32 Metal 65A ESC.
Remembering what happened with the last ESC I decided to check ESC immediately.
ESC #2 gave no beeps when connected to a motor and powered.
However, BLHeliSuite32 sees the ESC #2 w/o any problems.
In Betaflight motor check ESC #2 no spins a motor. ESC #1, #3 and #4 are OK.
What the hell is going on? The second ESC is DOA?
And supposedly one of the best ones - Tekko32.
Is it only my bad luck? Or such a shit happens often.
I always used SpeedyBee and Mamba ESC w/o any troubles at all.
But wanted to use something better and ironically got 2 "better" DOA ESCs
P.S.
I buy all the FPV stuff from AliExpress.
It's not my first build by far.
P.S.
