TBS Unify Pro shuting down
TBS Unify Pro HV, connected directly to battery, with antenna.
If it's without airflow (e.g. sitting on my desk) on any power >25mw, i.e. 200mw and 800mW it shuts down after a minut of so. Strange but is this a feature to prevent overheating.
It won't do that on 25mw.
According to what I read somewhere (can't remember where) I believe it was from TBS themselves, the unify should be able to run indefinitely at 200mw without cooling airflow, so you can have it inside a fuselage etc without issues. I run mine at 200 and I have it buried inside my micro one side double sided taped to the frame and sandwhiched under the battery strap so very little airflow and no issues
It's how it is, it shouldnt shotdown at 25mw but it will at higher powers if there is no airflow. all depepnds on how VTX is mounted
It also depends on how good the antenna is. If the antenna isn't well matched, or even worse, not properly connected, the signal gets reflected back to the output and heats things up much faster. Even if the antenna is well matched, if it's just lying on the bench, it's not going to radiate very well.
Also, check that the IPX connector that connects the pigtail to the board is firmly attached.
  Skyzone 04O PRO goggles SeismicCWave 27 519 17-Apr-2024, 06:19 PM
Last Post: SeismicCWave
  TBS Fusion vs Rapidfire vs Speedybee VRX modules at same price, which is best? Luk5569 21 702 09-Apr-2024, 09:03 PM
  Announcement TBS Fusion 2.34 (Beta) Firmware Released SnowLeopardFPV 10 5,011 06-Mar-2024, 01:27 AM
  TBS UNIFY Pro32 zomer 5 254 27-Feb-2024, 10:02 AM
Last Post: cst3x6
  New Product Skyzone SKY04X Pro Goggles (Analog) SnowLeopardFPV 13 1,513 30-Nov-2023, 03:26 AM
Last Post: Lukeman
