16-Aug-2017, 06:24 PM
I set up timer number 1 for 2 .5 minutes and activated with throttle. It worked to begin with but now doesn't seem to activate with throttle. Yes, I have reset it after each flight. Why would it stop working?
Taranis timer |
16-Aug-2017, 06:24 PM I set up timer number 1 for 2 .5 minutes and activated with throttle. It worked to begin with but now doesn't seem to activate with throttle. Yes, I have reset it after each flight. Why would it stop working? 16-Aug-2017, 06:26 PM What does it display when you apply throttle? Could you share a picture of or tell us the timer settings? carl.vegas Current Quads: Operational: Diatone GT2 200 In need of repair: Bumble Bee, tehStein, Slightly modified Vortex 250 16-Aug-2017, 06:41 PM (16-Aug-2017, 06:26 PM)Carl.Vegas Wrote: What does it display when you apply throttle? Could you share a picture of or tell us the timer settings? The timer displays 2:30. It is activated with throttle. I haven't changed anything since I set it up. It works sporadically. A voice calls out 2 minutes, one minute and then a final countdown to zero. I never know if it is working or not with my goggles on untill I realize that enough time has elapsed and I didn't hear the voice telling me 2 minutes. 16-Aug-2017, 07:55 PM So when you increase throttle above zero, now it does not count down from 2:30 then? As for the settings, you had to set them up somehow in the start... if I knew what your set up was I could try it on my radio to see if I could recreate the issue but if I set it up without knowing your settings then it'll operate the same way that it does on my radios now which is to work correctly. carl.vegas Current Quads: Operational: Diatone GT2 200 In need of repair: Bumble Bee, tehStein, Slightly modified Vortex 250 16-Aug-2017, 08:10 PM It doesn't count down. I just set up timer 2 the same as timer one. Timer 2 works while timer one is dead. Strange. Timer one worked for a few weeks then on and off , now off. It could be that timer one software is toasted. 17-Aug-2017, 01:35 AM Since it works as a function of the overall open tx operating system it's unlikely that the timer 2 program wpoyld fail without other problematic behaviors from the radio carl.vegas Current Quads: Operational: Diatone GT2 200 In need of repair: Bumble Bee, tehStein, Slightly modified Vortex 250 17-Aug-2017, 02:58 AM I appreciate your help. Let me mention that for about a monh I occassionally get a verbal message that the antenna is defective. I just delete it and keep flying. Do you think I might be in the beginnings of a Taranis meltdown? |
BetaFPV Elrs module not loading in a taranis X7 | Stumpy | 2 | 160 | 31-Jan-2024, 12:19 PM Last Post: Stumpy | |
Taranis & TD 100 [km] | zomer | 0 | 185 | 03-Sep-2023, 03:27 PM Last Post: zomer | |
Help RSSI callout Taranis QX7/OpenTX? | swequad | 1 | 254 | 13-Jul-2023, 03:05 PM Last Post: SnowLeopardFPV | |
No tools/menu available (Taranis QX7) | Felynx | 6 | 3,744 | 19-May-2023, 06:41 AM Last Post: BadRaven | |
Help [SOLVED] help on setting up Taranis to change vtx band and channel with LUA script | sim_tcr | 10 | 1,152 | 24-Apr-2023, 08:20 AM Last Post: sim_tcr |
