Taranis swtiches programming for 250 drone
I have a Question that I can't seem to find a straight forward answer.
What switches do you have programed an possibly mixes on your taranis plus for 250class drone? Any leads would be helpful. Thank you
I use 3-4 switches, I just use a switch for Arming, one switch for flight modes - horizon (although i use this less and less), one switch for buzzer and maybe another for blackbox if I have it on the mini quad.
SA: Arming and BEEP
SB: Flight Mode
SE: EXPO
SH: Enable Throttle after Arming (only when Trottle is down!)
SG removed because my fingers are there.
SE removed (same reason as above) and installed instead of SF for three position switch.
SD high and SH high for 0.5sec arms my quad if no throttle is applied.
SC: change between acro, level.
SA: mid - beeper, high - blackbox.
SE: activates PID tuning.
Pot on left side changes between Roll, Pitch, Yaw PID adjust.
Pot on right side Changes Between P, I and D.
SB: Up/down adjust PID value one up/down for each time it is toggled.
(15-Jan-2017, 12:37 PM)oyvinla Wrote: SG removed because my fingers are there.
Sounds interesting, willing to share an EEPE?
(15-Jan-2017, 01:37 PM)Mephi Wrote: Sounds interesting, willing to share an EEPE?
Sure, but what is an eepe? I can make a tutorial one of the following days
(15-Jan-2017, 01:54 PM)oyvinla Wrote: Sure, but what is an eepe? I can make a tutorial one of the following days
EEPE is a file saved with OpenTX companion of your model Settings...
You Import from your TX, click on the model and then File->save as.
  Help Tango 2 does not connect to the (TBS CRSF nano RX)drone receiver but updates it Maksym 1 164 25-Feb-2024, 12:34 AM
Last Post: Cake
  BetaFPV Elrs module not loading in a taranis X7 Stumpy 2 208 31-Jan-2024, 12:19 PM
Last Post: Stumpy
  [SOLVED] Radio wont pair when drone is powered via battery mulapickle 5 295 16-Jan-2024, 03:26 PM
Last Post: mulapickle
  Taranis & TD 100 [km] zomer 0 194 03-Sep-2023, 03:27 PM
Last Post: zomer
  Help RSSI callout Taranis QX7/OpenTX? swequad 1 266 13-Jul-2023, 03:05 PM
