Threads: 20
Likes Received: 15 in 6 posts
Likes Given: 1
0 I have a Question that I can't seem to find a straight forward answer.
What switches do you have programed an possibly mixes on your taranis plus for 250class drone? Any leads would be helpful. Thank you
Threads: 39
Likes Received: 16 in 11 posts
2 I use 3-4 switches, I just use a switch for Arming, one switch for flight modes - horizon (although i use this less and less), one switch for buzzer and maybe another for blackbox if I have it on the mini quad.
Threads: 2
Likes Received: 8 in 7 posts
Likes Given: 7
0 SA: Arming and BEEP
SB: Flight Mode
SE: EXPO
SH: Enable Throttle after Arming (only when Trottle is down!)
Threads: 66
Likes Received: 350 in 248 posts
Likes Given: 164
34 15-Jan-2017, 12:37 PM (This post was last modified: 15-Jan-2017, 12:37 PM by oyvinla.) SG removed because my fingers are there.
SE removed (same reason as above) and installed instead of SF for three position switch.
SD high and SH high for 0.5sec arms my quad if no throttle is applied.
SC: change between acro, level.
SA: mid - beeper, high - blackbox.
SE: activates PID tuning.
Pot on left side changes between Roll, Pitch, Yaw PID adjust.
Pot on right side Changes Between P, I and D.
SB: Up/down adjust PID value one up/down for each time it is toggled.
