Taranis Stop counting time
Need some advice, my taranis timer has stop counting time!
That is the second time it happens to me. The moment I give throttle it start counting time. Now it does not do anything, it is stop at 9h06 (9 hours 6 mins).
Look my very first model jammed at the exact same time! Back then I copy paste the model and created a new one and reset the timer.
Got any ideas?
Okay to my own question, in programming you have this data type call a "INT" or integer, you can store data in it. Well the maximum data you can store in a INT is 32767. 32767 in seconds = to 9 hours 6 minutes 7 seconds!
I uploaded the new firmware on my Taranis to fix all those issues. I have now 2.1.8 and my timer can go over 9:06:07!
boom have a great day!
  BetaFPV Elrs module not loading in a taranis X7 Stumpy 2 208 31-Jan-2024, 12:19 PM
Last Post: Stumpy
  Taranis & TD 100 [km] zomer 0 194 03-Sep-2023, 03:27 PM
Last Post: zomer
  Help RSSI callout Taranis QX7/OpenTX? swequad 1 266 13-Jul-2023, 03:05 PM
  No tools/menu available (Taranis QX7) Felynx 6 3,849 19-May-2023, 06:41 AM
Last Post: BadRaven
  Help [SOLVED] help on setting up Taranis to change vtx band and channel with LUA script sim_tcr 10 1,205 24-Apr-2023, 08:20 AM
Last Post: sim_tcr
