Taranis Question: Difference between EU, non-EU firmware?
Anyone know difference between EU and International Taranis ?
It's about regulations on transmission, although the output power are the same.
The firmware is different but the functionality is the same. You can flash your device to either firmware anytime you want. But most RX you get from China would be on international firmware (non-EU).
(19-Nov-2016, 12:38 AM)cche Wrote: It's about regulations on transmission, although the output power are the same.
From what I'd read on RC Groups the receivers flashed with EU firmware have a lower sensitivity?  So while the transmitter might have the same output the range is reduced.  Something to to with an increased data-rate requiring a more solid/stronger signal to get an error free data link.
Hello i would like to quit using Spektrum tx and buy a taranis qx 7 .
The question is:euro version and international versions output the same watt power? (Apart the different firmwares) because i know for sure that euro Spektrums tx are Lower powered than non euro.
And if i purchase a taranis from Banggood (hk) it will be euro or international?
Thx in advance
EU has no D8 and LR12 mode, because they do not comply with CE Regulation V1.8.1 ...
(20-May-2017, 11:17 AM)Mephi Wrote: EU has no D8 and LR12 mode, because they do not comply with CE Regulation V1.8.1 ...
Ok i know.thx. but i would like to know if the transmitting output power is lower on tx sold for Eu market
Anyone knows the rf output power of xjt module?
  Solved QX7 firmware updated...now bootloader missing. xcalibur 5 195 18-Jan-2018, 03:45 PM
Last Post: xcalibur
  Help R9M Long range module for taranis X9D Hermann 1 137 06-Jan-2018, 02:18 PM
Last Post: unseen
  Trust in my Taranis? CaCondor 3 211 21-Dec-2017, 07:33 PM
Last Post: Carl.Vegas
  Discussion LUA Script For Taranis Discussion Oscar 6 1,315 03-Dec-2017, 10:18 PM
Last Post: Oscar
  Help FrSky XM + Taranis Q X7, Problem with connection and firmware Neddail 4 1,251 26-Nov-2017, 05:26 PM
Last Post: Oscar
