05-Feb-2017, 08:33 AM
Hello everyone,
So my main flying ground is causing some issues. In some parts of the ground, the receiver very easily loses a phase and continues the last command until the phase comes back. These spots are not too far from where I stand, and this usually happens when the copter is upside down, such as halfway through a trick.
The field is surrounded by buildings(apartments) on 2 sides.
I thought it was an antenna issue, so I did the Taranis antenna mod and SWR seems good, but I'm still having the same issues. I did not have a problem flying hundreds of meters out and doing all sorts of maneuvers at another field, so I'm pretty sure the issue is with the field.
This is the only field I have regular access to(the other one was hours away) and it's now getting frustrating not being able to fly properly.
I even tried building a 2.4 CP antenna to use and that only made a marginal difference, it seems. Any ideas?
