Taranis 4 in 1 multi protocol module problem
Hello! I just switch from DEVO 7 to Taranis QX7
I purchased 2 XSR and bind it perfectly, then i decided to try this module to re-use my RX716
I flashed the OPENTX 2.2 with multi module, and finally bind the Tx to Rx
[Image: 18119693_10211572281996389_441586712_o.j...e=58FF1AED]
HOWEVER, the end point seems off a lot, and i don't know how to fix it.
as you can see, 1827 is the max while min is 1190.
I know how to do this with XSR (just reduce numbers)
However I can't increase the weight in output (over 100)
So do I miss anything?
Thanks for the help
[Image: 18110721_10211572283796434_2515592_n.jpg...e=58FFDFF1]
If you can't get the range to go from 1000 to 2000, even after using the travel adjustment, then it's possible that the receiver won't actually output more than that range. I have some micro DSMX receivers that do the same thing.
If that's the case, you need to use the rxrange command in the CLI to tell the flight controller what the actual range is. See: https://github.com/cleanflight/cleanflig...figuration
Once you enter the actual ranges, the flight controller will scale them into 1000 - 2000 for you.
  • DGworks
(23-Apr-2017, 03:51 PM)unseen Wrote: If you can't get the range to go from 1000 to 2000, even after using the travel adjustment, then it's possible that the receiver won't actually output more than that range. I have some micro DSMX receivers that do the same thing.
that works flawlessly!
Thanks for the help!!
[-] The following 1 user Likes DGworks's post:
  • unseen
(24-Apr-2017, 02:27 PM)DGworks Wrote: that works flawlessly!
My pleasure! I'm glad to hear it solved your problem.
  New Product RadioMaster Ranger 2W 2.4GHz ExpressLRS Module SnowLeopardFPV 10 5,155 20-Mar-2024, 10:53 PM
Last Post: V-22
  BetaFPV Elrs module not loading in a taranis X7 Stumpy 2 208 31-Jan-2024, 12:19 PM
Last Post: Stumpy
  Help Dji o3 rc link problem. Mad35 20 777 21-Jan-2024, 02:20 PM
Last Post: Mad35
  Problem with FRsky R9 900mhz PJKMBAKER 5 369 24-Dec-2023, 02:18 PM
Last Post: PJKMBAKER
  Zorro external ELRS module setup issues Prowler2424 1 344 16-Dec-2023, 09:28 PM
Last Post: matt0725
