23-Apr-2017, 03:03 PM
Hello! I just switch from DEVO 7 to Taranis QX7
I purchased 2 XSR and bind it perfectly, then i decided to try this module to re-use my RX716
I flashed the OPENTX 2.2 with multi module, and finally bind the Tx to Rx
HOWEVER, the end point seems off a lot, and i don't know how to fix it.
as you can see, 1827 is the max while min is 1190.
I know how to do this with XSR (just reduce numbers)
However I can't increase the weight in output (over 100)
So do I miss anything?
Thanks for the help
Thanks for the help
