Just added 8 more batteries to the result. And here is the takeaway:
- When you see the brand "CrazyPony" just run away!
- GNB batteries are generally good, but not all of them. Their C rating is not accurate, but still relevant. 80C are excellent, 60C are okay, anything lower just has too much voltage sag (does not apply to other brands)
- Expensive batteries don't equal good batteries. There are crappy batteries that cost a lot So make sure you check reviews before buying (actual testing, not fake reviews)
- "HV, not HV", doesn't really matter, just make sure you stick with one type so you don't mix them in charging (huge safety concern)
For the result:
https://oscarliang.com/whoop-toothpick-lipo-battery/
For the result:
