Takeaway after testing LiPo
Just added 8 more batteries to the result. And here is the takeaway:
- When you see the brand "CrazyPony" just run away!
- GNB batteries are generally good, but not all of them. Their C rating is not accurate, but still relevant. 80C are excellent, 60C are okay, anything lower just has too much voltage sag (does not apply to other brands)
- Expensive batteries don't equal good batteries. There are crappy batteries that cost a lot Smile So make sure you check reviews before buying (actual testing, not fake reviews)
- "HV, not HV", doesn't really matter, just make sure you stick with one type so you don't mix them in charging (huge safety concern)
For the result:
https://oscarliang.com/whoop-toothpick-lipo-battery/
  • UrbanJungle1966
  BT2.0 connector on 2S Lipo Pathfinder075 26 1,846 03-May-2023, 09:36 PM
  Tip & Trick Lipo's support for Tinyhawk 2 freestyle Krayon70 7 1,243 25-Jul-2021, 02:47 AM
  Help Mobula7 crazy LiPo tension variations Ahaw 5 1,058 21-Feb-2021, 10:36 AM
Last Post: Ahaw
  Help Help Betafpv f4 12a aio lipo only red led, lipo and USB everything works TwistedFPV 2 710 01-Feb-2021, 08:16 PM
Last Post: TwistedFPV
  Tutorial Make a 1S LiPo Batteries charging cable Oscar 19 32,657 18-Oct-2020, 09:49 PM
Last Post: brettbrandon
