Threads: 0
Likes Received: 3 in 3 posts
0 Just drill a bigger hole.
Threads: 50
Likes Received: 704 in 450 posts
Likes Given: 1,189
30 Hm maybe just bevel the hole on the upper side a bit, with a much larger drill for example. No need to drill all the way through.
Also this shouldn't weaken that spot, i've never seen an arm break at the center of the motor mount.
Threads: 125
Likes Given: 99
388 I emailed Armattan. They said just bevel the inside. I just didn't want to void the warranty on the frame by modifying it. Before I do that, I will likely trim the C-clip down.
Thanks for all the suggestion.
