Threads: 27
Likes Received: 11 in 7 posts
Likes Given: 1
3 I need help, i have done a new build. Kiss fc, dys xms30a, emax 2300kv 5045 tri blades, on 4s. I am having what seems to be sync issues, but I dont believe it to be, instead I think it might be the pdb that is not able to handle the amps required. When I give full throttle, my quad stalls for a second, but not every time. Can this be the PDB?
battery: Tattu, 1550mah, 45c, full charge
Threads: 25
Likes Received: 6 in 5 posts
Likes Given: 3
4 I don't think it's the PDB. "not handling the amps" results in heat and/or fire. Unless your PDB is really hot after flying, you're not overtaxing it.
I had the same issue before, its the amps, when I switched to 5045 normal prop, issues disappeared, will need get rid of pdb and go straight for wiring. Also need to get some bonka's lipos
Threads: 8
Likes Received: 11 in 5 posts
Likes Given: 25
1 Try puting your motor timmings down to low or medium/low. I havent used kiss, there maybe a firmware clash, try calibrating your motors through KISS GUI.
