16-Jan-2017, 10:33 PM (This post was last modified: 16-Jan-2017, 10:35 PM by bumpie. Edit Reason: Misspelled stupid in title. )
I am trying to do a antenna mod to extend my range and have run into , what seems to me to be a problem. I unsoldered my antenna connection from the transmitter. Then soldered the new antenna to the board from where I removed the original one. Then I grounded the shield. Just to be sure I didnt have a problem I checked the continuity between the shield and the antenna and got continunity. So---I unsoldered everything and checked the connection points on the board and they are both grounded. They look clean with no visible sign of shorting out. Did I screw up something or should they both be grounded? Doesnt make sense to me but I know zero about this. HELP!!!
