Syma X5C Fun With Super Easy FPV Conversion
The Syma X5C makes a fun FPV quadcopter.
 I removed the prop guards, the on board camera and the landing legs. I weighed them and was pleased to see they weigh the same as my little Eachine TX02 super mini 5.8GHz FPV Transmitter with FPV camera and Clover Antenna.
 I made a little mount for the camera/tx unit and velcroed it to the top of the Syma. It works great. The camera/tx plugs into the place where the picture camera plugged into. What could be easier? I am using 800 mah batteries to power the rig. The video is as clear as a bell, too. Big Grin
Attached Files Thumbnail(s)
[-] The following 2 users Like CaCondor's post:
  • Drone0fPrey, sloscotty
Ah you beat me to it!  Wink Well done!  Cool
Ive had my X5 for a long time now and planned on playing with a micro fpv rig for it as well as my Rustler truck! Just waiting on my first pair of goggles!
The Obsession IS Real!
I really enjoy flying the Syma around FPV but........................ Dodgy
After a few flights I did bend the antenna as the cam/vtx unit is sticking up on top of the Syma. I could see where this would lead. Eventually the antenna or cam unit would get trashed.   Cry
  So, I decided to put it inside the hollow frame. It was EASY!!
    1.  I took the shell apart and made some little opening cuts for the camera neck and antenna base to protrude through.
2.  Snip the little Eachine TX02 apart and solder small wires to the corresponding stubs.
3. Solder + and - ( red and black)  which is power and ground wires for the Eachine unit to the + and - on the flight control board where the wires come up from the socket used for the original Syma camera.
4. I used a hot glue gun to fix the cam at a slight up angle and the Flight control board where the squarish antenna base protrudes.
5.  Snap and screw the top shell back on. Believe me this is fun and EASY.
  The beauty of this set up is that the camera and the antenna are now out of the way and protected. Plus it looks stealthy and cool. Cool
Let us know if you do one up too.
  Willie B
  News FAA Endgame: No recreational FPV flying outside of a FRIA? SnowLeopardFPV 26 1,186 19-Mar-2024, 11:33 PM
  Hobby wing for fpv is like plant based “meat” is to a cow Rob Axel 3 160 06-Feb-2024, 11:58 PM
  FPV article / Talk with Lexie Janson Cyfly 0 218 21-Oct-2023, 11:24 AM
Last Post: Cyfly
  AI drone beats Pro FPV pilots FPVme 4 301 24-Sep-2023, 10:18 PM
Last Post: BadComputer
  Carrying FPV Gear for Quick Guerrilla Flights. FPVme 10 490 19-Aug-2023, 02:55 AM
Last Post: FPVme
