Superhero heat-shrink for 18650 batteries
ROFL I giggled to myself when visiting my local Vape Shop (E-cigarette store) this evening to get juiced up Wink
As I am browsing the display cases, this is what I found.
[Image: xY6jP1sl.jpg]
Needless to say, but, they had to be tested. Right?
[Image: GO6G3OUl.jpg]
Pretty tough match-up Wink
[Image: XuTar7ll.jpg]
Now I need some a bit larger, with flames Tongue to use covering ESC's and arms on my next build!
The Obsession IS Real!
  • fftunes
Haha nice Thumbs Up
If i had a use for those i'd take batman and spidey too!
  • Drone0fPrey
I actually plan to use these to make two 4400mah packs for my goggles. Only have one 2200mah pack at the moment. Just waiting for the new vape batteries Wink
Those should be wide enough to fit over a 20A ESC, no? (Cut off the bottom and just leave the head?)
I showed them to a friend, now he wants them so bad... Big Grin
If you happen to stumble across an online shop that has those, please share. Smile
https://www.ebay.com/p/?iid=172464715835 Big Grin
  • rryyyaann, fftunes
(09-May-2017, 02:14 AM)sloscotty Wrote: https://www.ebay.com/p/?iid=172464715835 Big Grin
Awesome, thanks! Smile edit. I mean, thanks a lot! Big Grin
(08-May-2017, 09:20 PM)sloscotty Wrote: Those should be wide enough to fit over a 20A ESC, no?  (Cut off the bottom and just leave the head?)
Well actually, if you just covered the ESC and not the arm as well, like I was thinking Doh  it would work fine for most. They would probably even fit my Racerstar MS35A's. Then I could just cover everything (ESC, arm, and LEDs) with clear for a clean look! I planned on grabbing more my next visit.
Ah, the power of multiple brains. Wink
And thanks for the ebay link.
  • sloscotty
Hey D0P, in case those are the elastic, "rubbery" type of shrink wrap, maybe you can stretch them a bit more? I do that quite often, however it's much easier with small pieces... i wouldn't have an idea how to stretch such large ones since you want to cover the whole arms...
However if it's the stiffer, plastic-ish sort it most likely doesn't work.
  • sloscotty
(09-May-2017, 05:32 AM)fftunes Wrote: Hey D0P, in case those are the elastic, "rubbery" type of shrink wrap, maybe you can stretch them a bit more? I do that quite often, however it's much easier with small pieces... i wouldn't have an idea how to stretch such large ones since you want to cover the whole arms...
Yes, it is the harder to stretch, plastic stuff Wink
Still might be worth a try to use a small (like 4mm) wrench and screwdriver as a way to evenly stretch it.
  • fftunes
  Fun With Heat Transfer Sheets the.ronin 2 317 01-Jan-2022, 08:49 PM
Last Post: the.ronin
  Fresh Batteries Make My Pitch Go VROOM! TheLostAlaskan 0 252 17-Sep-2020, 05:13 PM
Last Post: TheLostAlaskan
  Discussion How do you discharge your batteries? sloscotty 15 5,828 07-Jun-2017, 06:09 PM
Last Post: Carl.Vegas
  Build Potential build for spare 3s batteries K24cl9 9 1,177 01-Apr-2017, 11:04 AM
Last Post: unseen
