Sub $10 Servo Gimbal
Need or want a "tiny" gimbal to mount your FPV cam on?  Flying a small quad and want some sort of balanced GoPro footage?
There's a heap of really fast, awesome gimbals out that that are ready to strap onto you quad...  But what if you barely wanted to spend any money, had basic gimbal control on your FC and really just want to mount a small light camera?
You could do worse than this super cheap (and a little nasty) gimbal from Banggood!
Link to my Blog post on it:  http://excesstext.com/2016/07/22/buildin...al-drones/
Link to this nasty little gimbal at Banggood: http://www.banggood.com/2-Axis-Servo-Gimbal-FPV-Camera-Platform-Tilt-Support-9g-12g-Servo-p-973523.html
Builds: Mini-Quad  -  Tricopter
A Blog
That's a nice little gimbal. Check out this thread if you want to make it work with stabilisation: http://intofpv.com/t-cc3d-servo-gimbal
I did worse ;p - to make the simplest gimbal possible, I just hotglued 2 servos together to form something like this (sorry, it's dark and was not supposed to go public Wink ):
I used 2 360 servos because the idea was to control it manually + a CCTV cam mounting bracket. Tested with Runcam HD on a ground vehicle.
Standard 9g sg90 towerpro micro servos would be better to use as stabilisation. And you can get four for 8 bucks Smile
  Cheap transmitter gimbal replacements Rob Axel 2 463 12-Jan-2024, 11:46 PM
  Accessory Radiomaster Pocket gimbal drop! Bud13420 1 465 03-Jan-2024, 04:17 PM
Last Post: Alfonso Gordon
  Tutorial How to adjust Tango 2 Gimbal tension strength Ditty_FPV 0 884 15-Feb-2021, 06:33 AM
Last Post: Ditty_FPV
  Is there an easy way to use a stepper motor instead of a servo? (via taranis or FC) salukikev 1 3,243 01-Feb-2021, 06:19 PM
Last Post: EVILsteve
  Installed a GForce and racing gimbal on X9D Rob3ddd 0 411 18-Aug-2020, 06:25 AM
Last Post: Rob3ddd
