30-Sep-2016, 05:43 AM
Hey, I've been trying to figure this out for days... The quad flies great, but at about 1412 - 1480ish throttle I get a strange PID oscillation. The gyros look clean. The P and D's go crazy, but the I's do nothing. I'm very confused.
Xnova 2206-2300
Aikon 30a Blheli_s
Naze rev 6 (killed my Lux) Betaflight 3.0
5X4.5X3
Please help.
PS: i have fiddled with the filters, but really don't know what i'm doing...
Log file here:
https://drive.google.com/file/d/0B3qDFmP...sp=sharing
Xnova 2206-2300
Aikon 30a Blheli_s
5X4.5X3
Please help.
Log file here:
# dump
# BetaFlight/NAZE 3.0.0 Sep 11 2016 / 00:35:30 (a21694b)
# name
name NTI-5R
# servo
# servo mix
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -CURRENT_METER
feature -OSD
feature -BLACKBOX
feature -TRANSPONDER
feature -AIRMODE
feature RX_SERIAL
feature FAILSAFE
feature BLACKBOX
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
map TAER1234
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
aux 0 0 0 1950 2100
aux 1 2 1 1450 1550
aux 2 27 0 1950 2100
aux 3 12 1 1975 2100
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
adjrange 12 0 0 900 900 0 0
adjrange 13 0 0 900 900 0 0
adjrange 14 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# rxfail
rxfail 3 a
rxfail 5 s 1500
# master
set min_check = 1100
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 30
set rc_interpolation = AUTO
set rc_interpolation_interval = 19
set rssi_ppm_invert = OFF
set max_aux_channels = 6
set debug_mode = NONE
set min_throttle = 1060
set max_throttle = 2000
set servo_center_pulse = 1500
set max_esc_throttle_jump = 0
set use_unsynced_pwm = OFF
set motor_pwm_protocol = MULTISHOT
set motor_pwm_rate = 400
set servo_pwm_rate = 50
set disarm_kill_switch = ON
set small_angle = 25
set fixedwing_althold_dir = 1
set serialrx_provider = SBUS
set sbus_inversion = ON
set spektrum_sat_bind = 0
set telemetry_switch = OFF
set telemetry_inversion = ON
set frsky_default_lattitude = 0.000
set frsky_default_longitude = 0.000
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set battery_capacity = 0
set vbat_scale = 110
set vbat_hysteresis = 1
set current_meter_scale = 400
set current_meter_offset = 0
set current_meter_type = ADC
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_yaw = 0
set gyro_lpf = OFF
set gyro_sync_denom = 4
set gyro_lowpass_level = NORMAL
set gyro_lowpass = 100
set gyro_notch_hz = 0
set gyro_notch_cutoff = 130
set moron_threshold = 32
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 0
set yaw_deadband = 0
set yaw_control_direction = 1
set yaw_motor_direction = 1
set tri_unarmed_servo = ON
set servo_lowpass_freq = 400
set airmode_activate_throttle = 1350
set failsafe_delay = 10
set failsafe_off_delay = 10
set failsafe_throttle = 1070
set failsafe_procedure = AUTO-LAND
set gimbal_mode = NORMAL
set acc_hardware = AUTO
set acc_lpf_hz = 10.000
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = ON
set acc_trim_pitch = 0
set acc_trim_roll = 0
set baro_tab_size = 21
set baro_noise_lpf = 0.600
set baro_cf_vel = 0.985
set baro_cf_alt = 0.965
set baro_hardware = NONE
set mag_hardware = NONE
set mag_declination = 0
set pid_process_denom = 2
set blackbox_rate_num = 1
set blackbox_rate_denom = 1
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
# profile
set pid_delta_method = MEASUREMENT
set yaw_p_limit = 500
set dterm_lowpass_level = HIGH
set dterm_lowpass = 100
set dterm_notch_hz = 260
set dterm_notch_cutoff = 160
set vbat_pid_compensation = OFF
set pid_at_min_throttle = ON
set iterm_throttle_gain = 0
set pterm_srate_ratio = 85
set dterm_setpoint_weight = 150
set yaw_rate_accel_limit = 220
set rate_accel_limit = 0
set accum_threshold = 130
set yaw_accum_threshold = 32
set yaw_lowpass = 120
set pid_controller = BETAFLIGHT
set p_pitch = 60
set i_pitch = 65
set d_pitch = 16
set p_roll = 45
set i_roll = 40
set d_roll = 14
set p_yaw = 70
set i_yaw = 45
set d_yaw = 20
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 50
set i_level = 50
set d_level = 100
set p_vel = 55
set i_vel = 55
set d_vel = 75
# rateprofile
set rc_rate = 117
set rc_rate_yaw = 117
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_srate = 78
set pitch_srate = 78
set yaw_srate = 75
set tpa_rate = 10
set tpa_breakpoint = 1650
