05-Apr-2022, 09:19 PM
Hi guys,
I was hoping you can help. I have recently got back into RC Flying after a long break. Having dived into FPV, I also fancied combining my 3D printer and creating something that flew. I printed and built the Avatar Bi-Copter but I am having a bit of an issue. I am new to flight controllers and betaFlight and can’t fathom what’s causing the issues.
Problem 1: When I arm the copter, occasionally motor 2 struggles to start. This seems to gets worse after a couple of hard ish landings (the reason for which is below).
Problem 2: when I start to power up the copter, the blades, controlled by 2 servos, twitch and start to angle backwards. You can see the behaviour when the copter isn’t armed and I simply push the throttle forwards in the first video.
Problem 3: the main one and the reason for the firm landings. If I manage to get the copter off the floor, the blades, alternate flipping forwards and backwards and essentially make the copter shake violently and you have to put it back on the deck. When this does happen, the blade lock into a position normally pouting towards the rear.. the o my way to reset them is to disarm the copter and they reset. I have attached a video showing the behaviours listed above.
I am using a Matesky F4 Flight controller using motor positions 1 & 2 for the motors and 3 & 4 signals for the servos. All of this is set up in BetaFlight.
If anyone can point me in the direction of possibly curing this I would be so grateful as it is driving me insane!!
