Threads: 6
Likes Received: 18 in 7 posts
3 31-May-2020, 09:17 PM (This post was last modified: 01-Jun-2020, 03:20 PM by rdsi55.) Using BF 4.1.6 I'm only able to access stick OSD if I arm with the throttle let's say mid throttle then do the yaw left, pitch up. Once the menu appears I can flip the arm switch off & proceed as expected.
If I try it without arming all I get are 4 flashing asterisks like so "* * * *".
Should the stick OSD be accessible without having to arm the quad first ?
This is happening on 2 different quads I've built - one using a Flywoo Goku F722 mini and the other a SucceX Micro F4 V2.1.
Thanks
Threads: 125
Likes Given: 99
388 You should be able to get into the OSD menu (CMS) without arming. You should not be able to access the menu when armed.
I think you have turn on a setting that only registered throttle when you arm. I can't remember where that setting is at the moment. I have to dig around a little.
Threads: 587
Likes Received: 8,965 in 6,634 posts
Likes Given: 1,425
787 Can you please run both the "dump" and "diff all" commands in the Betaflight Configurator CLI tab and copy/paste the results back here. If you've inadvertently managed to switch on an obscure setting then it should show up in the diff.
Threads: 125
Likes Given: 99
388 Another question, did you added some logic switch in your radio or modified the throttle channel in the radio?
Threads: 125
Likes Given: 99
388 I think this is your problem.
Switch(SF▼) [Cut]
Is SF your arm switch?
