Standalone Server power supply mod [ Fujitsu DPS-800GB-3 A ]
Information
I found a brand new  spare powersupply at work for Fujitsu RX300 S6 Servers that was no longer needed and wanted to modify so it is activated all the time. The activation is usually done by the communication with the mainboard.
After googling for 30mins i realised that Delta and HP made a similar power supply that has somewhat a little bit different Pin layout. Since I found no post about the Fujitsu I decided to post my simple guide so people won't have to deal with the same problem in the future.
Two bridges need to be made:
- Between PIN 31 and PIN 34
- Between PIN 26 and any Ground connection
The powersupply spits out a Juicy 12V @ 66Ampere
After this is done you can solder on any kind of connector you want to attach the supply to your charger
Label
Top Side
Bottom Side
Running Powersupply
[-] The following 5 users Like Apicalis's post:
  • fftunes, Oscar, oyvinla, sloscotty, KonradS
No you didn't. All you did was spam the forum with a link to your site.
Given the terrible English in use on the site, I'd counsel people not to click the link in the previous post unless you use some kind of script blocker.
  Discussion Hota D6 internal resistor mod for faster balance charging? PewPewPewRawr 1 301 13-May-2023, 06:47 PM
  Discussion Power supply dying? matt0725 3 351 03-Mar-2023, 09:19 PM
Last Post: sevro
  Using my 3d printer’s power supply for Isdt608AC Cygi 1 323 16-Feb-2023, 01:29 PM
Last Post: ph2t
  Can I power my drone from a charger mattp 8 1,645 31-Dec-2021, 04:59 PM
Last Post: mattp
  Is there a DC power supply & Balanced Charger 2-in-1 product? leestrong 8 965 16-Jun-2021, 02:14 PM
Last Post: leestrong
