I just built a qav180 with a spracing f3 evo flight controller but it drifts to the right in angle mode. If I rotate the board it drifts to same side of board, so it's definitely the board. I have calibrated it 100 times on different surfaces with no luck. I can trim the accelerometer but then the machine doesn't pirouette flat. The only fix I have found is to take a shish kabob stick and place it under the side that drifts when I calibrate the accelerometer and then it hovers flat and pirouettes flat... I have same results in both betaflight and cleanflight. My other quad with regular f3 board doesn't do this. Am I missing something? Has anyone else encountered this? Spracing doesn't seem to have any contact information or support.
SPracing f3 evo problem |
14-Mar-2017, 09:35 PM Trichome, I realize this is a while after your post, but did you ever solve the problem? My buddy just got his SPRacing F3 setup (his is most likely a cheap clone) and he has the exact same issue. The one piece of advice I got but haven't tried yet is to soft-mount the FC. Did you try that? |
Help Problem with GEP-F411-35A AIO + VTX V1 Walksnail | Adam0880 | 2 | 282 | 09-Mar-2024, 08:35 PM Last Post: Adam0880 | |
Help Problem accessing the ESP8285 chip on MATEK FC F405 WTE | remi.auge | 2 | 193 | 05-Mar-2024, 12:49 PM Last Post: remi.auge | |
Issue "Mixer Mode Problem detected" need help | Steven FPV | 9 | 287 | 24-Jan-2024, 06:36 AM Last Post: Steven FPV | |
Diatone stack current sensor problem | Myman | 10 | 1,526 | 27-Dec-2023, 12:02 AM Last Post: Birbal | |
Help Matek 411 Wing BAROMETER problem | capediablo83 | 0 | 135 | 19-Dec-2023, 04:15 PM Last Post: capediablo83 |
