Speck 80 - 1s Brushless!
Thanks to Hamster for turning me on to this cool little frame, and to Oscar for the nifty little MX MWC-32X flight controller!
Parts list:
Speck 80 frame: RotoriousFPV.com
MX MWC 32-X 1s/2s FC: OverskyRC or Banggood
RotorX RX1102-7800kv motors: RC-Drones
MX-3A 1s ESCs: Hobby King
1.5mm 3-pin JST-ZH pigtails: Ebay
RotorX RX2535W props (cut down to 2 inch): AirbladeUAV
Quanum Elite micro cam/vtx (de-cased): Hobby King
NanoTech 1s 500mAh 25-50C lipos: Hobby King
Custom 3D printed motor mounts: Thingiverse
The Speck 80 frame kit comes with a top plate and camera cage (which I did not use), and a nice flexible printed mount for the camera I chose.
The MX MWC 32-X FC is neat but required some special consideration to work with the motors and frame.  First of all, the motor/esc input plugs are 3-pin and requires ESCs work with only one power, one ground, and the signal. (The MX-3As do - there is also a 2s version of these that I will probably switch to eventually.)
Also, the FC's hole spacing was slightly smaller than the mounting holes on the frame, so I filed the holes slightly toward the outside for a good fit. I decided to mount it inverted and it also needed to be rotated.  I decided on 225 degrees to get the battery pigtail where I wanted.  This meant that motors 2 & 3 crossed over under the FC.
With the board inverted and rotated 225 degrees, that makes motor connector 3 point forward.  I added M2 nuts on top of the board as spacers for the camera mount.  I had soldered on a small pigtail to match the pigtail on the camera (instead of soldering the camera directly), so I could easily disassemble the whole thing later.
Weight without battery is around 44 grams.  Flying weight is 59 grams!
I really like the looks of this little guy.
Unfortunately,  when attempting a hover test, motor three would not spin up.  After tearing it apart and testing motor and esc (again), I discovered that port 3 on the board was not working. USB port also quit working (don't know if related or not).  I have a new board on the way, and may go ahead and upgrade it to 2s.  The weight without battery shouldn't change - the 2s ESCs are nearly identical.  I will probably try it on the 1s first though, just to see.... Wink
EDIT:  I think I probably burned that port myself.  Early on, when I was testing motors, I burned out a motor because my mounts exposed too much screw and the screws touched the windings (I think).  It could have been port 3 that I was testing on (not sure).  The USB was still working after that though, so I'm not sure what happened there.
  • fftunes
I want one!
Me too!
If you decide to build one and go 2s, you can ask oversky to presolder the correct pads for 2s (can be switched). Also, you'll want these: http://www.banggood.com/MU-3A-2S-Speed-C...00574.html
I wonder if these will be suitable on 1S: http://www.banggood.com/4X-Racerstar-Rac...mds=search. But it shouldn't be too hard to rewind them for 2S.
These ESCs are way overpriced :-( Also no info on their weight.
Nice build, first one I've seen with a brushless system. If anyone is interested in buying one make sure you buy from Jack, his previous business partner has copied all of his designs.
[-] The following 2 users Like HamsterFPV's post:
  • Tom BD Bad, sloscotty
(14-Oct-2016, 01:12 PM)AndreyM Wrote: I wonder if these will be suitable on 1S: http://www.banggood.com/4X-Racerstar-Rac...mds=search. But it shouldn't be too hard to rewind them for 2S.
I think those motors would work well (wish I'd seen them before the 1102s). The 1102s are 3.5 grams with wires. You would still need to make a mount for the Speck 80 though - the only holes on the frame are ~11mm apart. You'd also need press-fit props or some collet-style adapter.
The MX-3A 1s ESC's I used are 0.38 grams without wires.  I think the form factor of the MU-3A's are the same, so I expect the weight to be comparable.  I agree about the cost. Depending on your flying style and prop-size, you could also exceed 3A (on 2s), but I doubt if I will push it that hard for long enough to burn.
That looks really tempting! Big Grin glad you found good use of the FC! It would still be sitting in my toolbox if I didn't send it away lol
that thing is tiny, looking forward to your videos
  • sloscotty
I just noticed that Banggood has the same FC (different name) for less than Oversky.
http://www.banggood.com/Micro-Scisky-MX-...57409.html
It shows a picture with receiver, but not sure it comes with that. You can add your own tiny rx (there are basic indications of how at Oversky).
(14-Oct-2016, 11:21 PM)Oscar Wrote: That looks really tempting! Big Grin glad you found good use of the FC! It would still be sitting in my toolbox if I didn't send it away lol
I did film my attempted hover, but...well...Big Grin
If you want to buy a Speck 80, RotoriousFPV now has a web-site - went live today.
http://rotoriousfpv.com/product/speck-80/
I posted a picture of this over on https://www.facebook.com/groups/RotoriousFPVGroup/ a couple of days ago.  It got a good response, and it sounds like Jack is going to design a brushless version of the Speck 80.
I want to build a copter like this. Can you help me to find 1-2S(both) FC, and need an FrSky receiver. Thanks!
(05-Nov-2016, 08:11 PM)KaiotEch Wrote: I want to build a copter like this. Can you help me to find 1-2S(both) FC, and need an FrSky receiver. Thanks!
I think Jack over at rotoriousfpv (see links above) is currently prototyping a modified Speck80 based around the FuriousFPV Piko BLX FC and maybe some (as yet to be released) 2-in-1 stackable ESCs (also from FuriousFPV) with 1104 motors.  You could wait and see what develops there.
I am modifying mine to 2s using the flight controller mentioned in my original post and using the Racerstar 6A ESCs from banggood.  (Not sure it's going to work yet - I'll post results when I'm done.) The Oversky FC can be modified for either 1s or 2s (or you can order pre-setup for which ever you want).  Banggood carries these as well: http://www.banggood.com/Micro-Scisky-MX-...57409.html .  These FC can also be modified to accept other receivers - they support PPM and SBUS with the adjustment of some solder pads.
My replacement board just arrived a couple of days ago, so I'm going to test it on 1s first before I do the conversion to 2s.
(05-Nov-2016, 09:15 PM)sloscotty Wrote: My replacement board just arrived a couple of days ago, so I'm going to test it on 1s first before I do the conversion to 2s.
Have you managed to do any testing yet, I would love to see some video to check out the performance of this little guy!
(18-Dec-2016, 05:40 AM)Tom BD Bad Wrote: Have you managed to do any testing yet, I would love to see some video to check out the performance of this little guy!
I got it rebuilt, tested, ran into another minor problem, and before I got it sorted out, Jack released the Speck 80 brushless frame mentioned in a previous post.
So I decided to hold off.  This is a lighter, stronger frame and is designed for 20 x 20 FC's (Pico BLX, Femto, etc) and up to 1105 motors.  Mine should be here in a couple of days.  Expect a full report by the end of the year (probably in a new thread).  In the meantime, check out the Rotorious FPV Underground Group (you'll need to join and be approved).  People are already starting their builds.  (Jack released 3 different brushless frames.)
#15
If someone is interested in building brushless indoor quadcopter from scratch here is an interesting project to look into:
http://fishpepper.de/projects/pepperf1sh/
It's definitely in top 3 on my projects list Smile
Cheers.
  New Product HBRC D0603 0603 Micro Brushless Motor flightmode0 4 182 05-Jan-2018, 02:38 AM
Last Post: JukeJoint
  Interest in a 90mm Ducted Brushless Micro? zanek012 1 181 08-Nov-2017, 06:01 PM
Last Post: unseen
  1S brushless Bat 100, sub 30g, under $100 Tom BD Bad 9 1,249 23-Oct-2017, 08:44 AM
Last Post: Tom BD Bad
  Small Brushless quad? Oscar 1 322 09-Oct-2017, 09:17 PM
Last Post: ZERONEST
  Review Awesome Q95 - an AWESOME Brushless micro FPV Drone Danq0 3 657 23-Jul-2017, 03:24 PM
Last Post: Drone0fPrey
