Spec sat rx bind issue
Im having issues with my spectrum sat rx's keeping bind. I have to rebind everytime i power up. Its happening to both my spectrum quads. I have kiss fc on both. Can someone tell me why and how to fix this please? Thanks.
You may already be doing this, but just to make sure:
When powering down, unplug the quad first, then turn off the transmitter.
When powering up, turn on the transmitter first, then plug in the quad. (Make sure the Tx is on the correct model first.)
(I had to mention this, because some DSM receivers go into bind mode immediately if a Tx signal is not found.)
(16-Jan-2017, 10:35 AM)sloscotty Wrote: You may already be doing this, but just to make sure:
Thanks but yes I always turn on the radio first. I'm only new to quads. I've beem in RC for over 35 yrs. These two quads are new to my fleet. I have two others that work fine.
[-] The following 1 user Likes fearfactorfred's post:
  • sloscotty
If you are using Clean/Betaflight, you might check the spektrum_sat_bind parameter (in CLI type "get spektrum_sat_bind" - no quotes). It should be 0 - if not use "set spektrum_sat_bind=0" and "save". I can't suggest anything if you are using kiss firmware. Maybe someone else can chime in. Good luck!
  • fearfactorfred
Thanks, i found some videos and will be giving that a try.
  VTX issue - ATOMRC hurricane 5 bar1 1 170 10-Mar-2024, 12:36 PM
Video Troubleshooting motor issue - I'm stuck, help! doraymon 7 294 25-Feb-2024, 05:48 PM
  Solved SPI V3 ELRS won't bind nicetomeetyou 5 374 23-Feb-2024, 05:22 PM
Last Post: nicetomeetyou
  issue in walksnail x Eyes.fpv 0 146 09-Feb-2024, 07:15 PM
Last Post: Eyes.fpv
  cant bind hammerman 2 200 31-Jan-2024, 02:18 AM
