15-Mar-2017, 01:29 AM
I am flying a Storm type A V3 racing drone which has a SP racing F3 flight controller. On the last flight at about 20 feet off the ground, it stopped flying and dropped to the ground. No obvious damage. When I tried to start it, one of the motors would not spin. After checking, I found the the processor chip on the flight controller was shorted. All the motors and ESC's were fine. I replaced the flight controller. I flashed the flight controller and loaded the data before soldering the connector on the flight controller. With the controller installed, I started the drone and everything seemed OK. I then took it outside and tried to fly. Only 2 motors spun. After checking, the flight controlled was shorted again. I have looked over the power board and cannot find any obvious shorts or bad parts.
Does anyone have any suggestions?
Thanks.
Thanks.
