The story so far...
- upgraded motors to EMAX RaceSpec 2205 2300KV Motor and put 3 blade props on (also new)
- flew it fine yesterday, just after finishing the upgrade
- fly it today and it flies off after adding abit of throttle ,and have to disarm and let it fall to the ground
- been trying to fix it by recalibrating ESCs changing PIDs but nothing seemed to work (had 1 working flight after it flying off many times not had another since. Not too sure why it worked then)
- went on the kiss FC GUI to see what the motors were doing
- had props on,holding loosely in my hand while it was plugged into pc and armed
- for the first few seconds it is fine, what you would expect for holding it ,all the motors climbing slowly
- either after a while or by putting some thrust input (15/20%) the outputs go crazy and it want to fly out of my hand ,not at max throttle though
- but throttle back to 0 and the motors are still going at the same speed and output still going crazy(I have it so you can still control the quad while on 0 throttle)
- at this point it would have started flying off in the field but i still have control over the orientation
The same thing happens when it is in the field
PIDs & Settings
Quad specs
Motor: EMAX RaceSpec 2205 2300KV Motor
FC: Kiss FC
ESCs: Eachine Racer 250 Drone Spare Part Simonk 12A ESC 2-4S (slowly switching all parts out from the eachine)
Props: 5x4x3
Thanks in advance for any advice.
- arm
- small throttle burst
- wait
- disarm
PIDs & Settings
Quad specs
FC: Kiss FC
Props: 5x4x3
