22-Jan-2018, 12:54 PM
Hi all... I have an HGLRC F4 V5Pro AIO Flight Controller.
I notice on the manual that the PDB has positive plates for all the ESCs on the top surface of the PCB and also a positive plate for 2 positive leads also on the bottom surface of the PCB -
The signal point also goes all the way through both sides of the PCB. (negative plates are also the same configuration)
My question. If I want to keep my wiring isolated by soldering two positives on top and 2 on the bottom surface of the PCB - which of the positive ESC leads do I use where? or are they interchangeable?
I've uploaded some screencaps of the manual and highlighted the plates in red pen...
Cheers
D
Cheers
D
