28-Jun-2016, 03:47 PM
My thoughts are to run osd over uart 2 and telemetry on soft serial for my taranis. I have tried pins 7 and 8 together linke to smart port wire on my FrSky X4R-SB.
Soft serial X Racer F303 v2.1 |
28-Jun-2016, 03:47 PM My thoughts are to run osd over uart 2 and telemetry on soft serial for my taranis. I have tried pins 7 and 8 together linke to smart port wire on my FrSky X4R-SB. does this help? http://intofpv.com/t-xracer-f303-fc-v2-n...34#pid2534 have you enabled soft serial? have you chosen "Smart port" in the telemetry option in "Port Tab"? another thing to check is your looptime, for F1 board it shuts down soft serial when running low looptime, i don't know if this is the case for F3 boards... but try to run 1Khz just for testing soft serial... 28-Jun-2016, 07:27 PM Yes I have enabled soft serial, smart port option etc, will check my loop time though. Are most people sacrificing telemetry for osd? I don't see much info on people doing both and running sbus. I have also read that post. 28-Jun-2016, 08:02 PM (28-Jun-2016, 07:27 PM)Maverick_fpv Wrote: Yes I have enabled soft serial, smart port option etc, will check my loop time though. Are most people sacrificing telemetry for osd? I don't see much info on people doing both and running sbus. I have also read that post. i think people normally only use one or the other... end of the day we just want to know what the battery voltage is... |
Help Diatone MAMBA F405 MINI DJI FC default CLI dump or soft serial setup | Original | 12 | 2,498 | 27-May-2023, 12:38 PM Last Post: Original | |
JHEMCU GSF-405ABMI 3.5g budget 1-2S AIO serial ELRS, Baro, Blackbox, plentyUARTS, i2c | mstc | 7 | 558 | 10-Mar-2023, 09:02 PM Last Post: romangpro | |
Help Can I use soft serial to get another uart on this FC? | Rob3ddd | 2 | 630 | 10-Oct-2022, 12:07 AM Last Post: Rob3ddd | |
FAILED TO OPEN SERIAL PORT | MicroFn | 5 | 679 | 11-Dec-2021, 04:47 PM Last Post: hugnosed_bat | |
3 serial connections on F411-WSE? | rsilk49 | 21 | 8,300 | 26-Jan-2020, 01:18 PM Last Post: SnowLeopardFPV |
