So many antennas
there, so many FPV antennas out there which one ??? let me mention some famous and some infamous :
VAS Bluebeam ultra , VAS Airblade , VAS racespec , VAS duraspec , VAS Cylcone , VAS/TBS triumph , IRC/FS spironet , Aomway's , foxeer v2's , Lumenier/TrueRC AXII , Menace rc raptor (pagoda) , prodrone's , fpvmodel dragonfly booster
so which are the best??? you guys tell
[-] The following 1 user Likes Ahmad Ilyas's post:
  • KonradS
"the one that you have attached to your quadcopter" and "the one that works"
i've tested few... and i didn't see any major difference between DIY and the other ones - however i fly no further than 500m from my self...
All the best
Grzesiek (Grisha/ Greg)
thinking about building: 450
thats totally true
you know i want to how booster antennas perform may be they could be a cheap gold
I use the TBS Triumphs and I love them!
I use a triumph on the quad and aomway and spironet patch on the goggles. I did try the second triumph on the goggles, but I found the aomway to perform better as a receiver antenna. It could be random, as I only tested it once, and it wasn't very much difference. Could be other causes as well. Anyway, since the triumph come as a pair, now I got two of them for two different quads Smile
I'm staying with Aomway, cheap and crash-proof. I only managed to damage one (one of the leaves broke at one end, easily soldered back together).
(19-Dec-2016, 11:06 AM)fftunes Wrote: I'm staying with Aomway, cheap and crash-proof. I only managed to damage one (one of the leaves broke at one end, easily soldered back together).
They are good antennas, but I can't say I agree with you regarding crash proof. Especially if the antenna is mounted so it could be hit by the props in a crash. I have destroyed several of them where I assume that the lobes got ripped off by the props. But if you can find the lobe, it is easy as you say to solder it back on Wink
[-] The following 1 user Likes oyvinla's post:
  • fftunes
(19-Dec-2016, 12:48 PM)oyvinla Wrote: They are good antennas, but I can't say I agree with you regarding crash proof. Especially if the antenna is mounted so it could be hit by the props in a crash. I have destroyed several of them where I assume that the lobes got ripped off by the props. But if you can find the lobe, it is easy as you say to solder it back on Wink
Having ripped off rx antennas before, i got very cautious about parts that could get into prop arc. I don't doubt that a prop could completely destroy the aomway antennas.
But on the other extreme, i had more than one crash where they were exposed to the full impact force (basically "landed" on the antenna, lol), and even though they had funny shapes after that, they all continued working without a problem.
However, all those big clover leaf antennas aren't the lightest. Does anybody here have experience with small linear antennas, like the one for example mattystuntz is testing here?
I'm wondering wether this would be good enough if NOT used with diversity and dedicated ground station. In my experience cloverleaf on goggles / fatshark plastic-stick antenna on quad wasn't any worse than cloverleaf on both, but that antenna in the video is extremely small...
i've flown on stripped dipole antenna on fpv when i was down on the cloverleafs... in result i've bought one dedicated from BG... range was good, video was good only issue it was destroyed in first crash Big Grin
only time i've seen the "bad signal" was having the cloverleafs RHCP and LHCP... but when i had cloverleaf + dipole i was good
All the best
[-] The following 1 user Likes Grisha0's post:
  • fftunes
(19-Dec-2016, 01:43 PM)fftunes Wrote: Having ripped off rx antennas before, i got very cautious about parts that could get into prop arc. I don't doubt that a prop could completely destroy the aomway antennas.
That antenna on the picture is the same as what's inside the plastic-stick antenna. I have de-sticked a couple of them and use them on micros. I have flown about hundred meters away without issues, but I do use realacc rx5808 diversity and a patch antenna on my goggles.
  • fftunes
  Alternative - chinese DJI goggles antennas pattap 0 276 05-Aug-2022, 10:57 AM
Last Post: pattap
  Carbon Fiber Interference on Antennas & GPS? the.ronin 3 1,770 30-Mar-2022, 05:47 PM
Last Post: the.ronin
  Getting ready to build Gen 3 versions of 915mhz RX antennas Krohsis 8 1,123 16-Jan-2020, 05:11 AM
Last Post: roger74
  Discussion How do you protect your antennas? t3rminal 17 2,279 03-Aug-2017, 11:15 PM
Last Post: unseen
  Placing antennas inside the carbon frame - how bad it will be? E.L.K. 11 4,537 11-May-2016, 01:20 PM
Last Post: Trollhammered
