Smartaudio help unify, kiss
Hi all
I have connected my unify with kiss and x4r as per Oscars turorial, I can pick up everthing from page 1 to 5, i have tried to change the channel and grout on taranis to see if it works, but it doesnt work, do i miss something, have i done something wrong.
If i select vtx and then vtx config type I can only see IRC Tramp, and not unify(does that make any difference).
I think Unify is under the Smartaudio "VTX SA"
Where will that be.
What betaflight firmware do you have?
Under "Features" you should see "VTX SA" and "VTX TR"
I use kiss not betaflight
Sorry, I was assuming. I can't help you.
I do know, it makes a different whether you choose Tramp or Smartaudio. They are different protocols.
  Fettec/KISS Stick Adjustments FPVme 4 289 27-Jun-2023, 03:45 AM
Last Post: FPVme
  Kiss ultra fcfc v2 pinout Egg_FPV 1 2,450 20-Jun-2023, 05:51 AM
Last Post: Egg_FPV
  Using blheli with KISS G4 what pwm should I set too? epicjfpv 0 176 29-Nov-2022, 04:47 PM
Last Post: epicjfpv
  Alien 5 kiss kit / build from 2018 - Need guidance SteveL 2 399 03-Jan-2022, 06:14 PM
Last Post: Banelle
  five33 smartaudio setup ? niuk 3 316 16-Sep-2021, 06:19 PM
