Skyline32+OSD F3 FC
Emax is releasing a F3 flight controller with built-in OSD - the Skyline32+OSD F3. Excited to see how it performs in my 3" build !
Good
  • Good for tight builds with limited space
  • Solder pads for direct soldering to the VTX and FPV camera
  • The OSD allows you to tune your multirotor on the field using OSD menu and radio transmitter sticks
  • No need to worry about OSD wiring and setting up
  • Flash memory chip
  • It has 8 PWM pins (motor outputs) and supports Tricopter, Quadcopter, Hexacopter and Octocopter config
  • I like the fact that for UART you have the choice of using either header pin holes or JST connectors. (UART 1)
  • It allows you to connect your OSD + SmartPort + SBus + GPS + LED Strip + Battery Monitoring + Sonar + 8 motors – all at the same time!
Not so good
  • Confusing pinouts
  • Full of JST connectors
  • Using MPU6050 but with I2C
My full review: http://blog.oscarliang.net/skyline32-osd-f1-f3/
[Image: RcVMFRrl.jpg]
Attached Files Thumbnail(s)
  New OSD Font for WTFOS, Walksnail - Super_Sneaky Oscar 0 1,037 29-May-2023, 04:03 PM
Last Post: Oscar
  Full MSP OSD for DJI FPV System - Now available! V-22 16 5,535 05-Dec-2022, 04:35 PM
Last Post: fpvapnea
  OSD Furious Piggy OSD Oscar 11 9,654 04-Dec-2021, 01:27 PM
Last Post: Chartwalker
  DJI HD gets OSD and other stuff Krohsis 7 2,617 09-Dec-2019, 04:36 AM
Last Post: zenm8
  FC DYS XBR220 F3 OSD integrated PDB Oscar 14 5,496 26-Apr-2019, 01:19 AM
Last Post: voodoo614
