23-Jan-2017, 01:44 PM (This post was last modified: 23-Jan-2017, 11:13 PM by sr_intofpv.)
I have a Skyline32 Acro (it says v1.1 on the board). ESCs are Emax BLHeli 12A
It came out-of-the-box with Baseflight, which I pulled off and flashed Cleanflight (v1.14.2) shortly after building my quad.
Cleanflight seems happy in configuration mode: sensors and tx/rx all picking up well. When I plug my battery in (while FC powered by USB) the ESCs don't 'trigger'. (By 'trigger' I mean their power-up beep/tune cycle.). If I 'save and reboot' in cleanflight, the ESCs then trigger and at this stage the motors spin up at a low rate. While connected via USB I can arm (motors spin faster) and then 'fly' - motors react appropriately to TX input.
If I try to 'clean' start the quad, i.e. no USB, the FC boots, then the ESCs 'trigger' and motors spin. Arming and 'flying' doesn't do anything.
I'm setting up an aux switch for arming - so it is not stick position dependant.
If I flash baseflight onto the FC (version b6a002e/2015.08.27) - it all 'just works'. I can set up my aux input to arm, do bench tests through baseflight, etc.
When I connect my battery while the FC is USB powered, the ESCs 'trigger' right away. The motors don't spin while not armed. Arming and 'flying' works as expected. In fact, I could calibrate my ESCs using baseflight - I was not able to do it on cleanflight.
Without USB power, the quad powers up appropriately when battery is connected, can be armed and flies well (assuming a competent pilot )
All my baseflight/cleanflight settings are default with the following changes:
I've trawled the forums and been through these posts, but they don't seem to quite describe what I'm seeing:
http://intofpv.com/t-skyline32-advanced-help
http://intofpv.com/t-signal-not-getting-to-motors
-Ray
(Edit: changed topic for Baseflight - not betaflight)
- aux input for arming, and another for angle/horizon/rate.
- oneshot enabled
- accelerometer calibration
- magnetometer calibration
- I let my motors spin when armed - just so I can see they're armed.
- The Throttle values all seem to be the same between Baseflight and Cleanflight
- My board orientation/yaw is 0 (FC facing 'forwards')
-Ray
