skyline32 FC, ESC Desync
I have a skyline32 FC that seems to have weird issue: motors are seriously desyncing when I use transmitter. Swapping ECS/Motors around does not seem to have an effect: it's always channel 2 & 3.
Everything is calibrated, ESCs reflashed couple of times (BLHeli now). Input from TX is correct (used two different TX and RX). If I move motor slider in openflight, motor reacts as intended. But not with TX.
I have that on 1.12 cleanflight, interestingly enough, betaflight is actually almost fine.
Is it something specific to Skyline32 (read: it's dodgy), or am I missing something?
I'm running a skyline32 v1.1 acro I had this problem when I first got it. But a quick escorts and accelerometer calibration all was good
Try a different version of betaflight first.
But out of 3 i ordered, I had one that did this no matter what firmware I put on it. I ended up ditching that one. I think it's just hardware related to bad quality control
I have this FC too. Try installing BetaFlight  RC1.13 and re-flash your ESCs through the flight controller (it didn't work on skyline32 until RC1.13). I was having ESC issues (meltdown) and since I installed RC1.13, no problems. The ESCs were getting so hot that the solder melted and the parts moved...and then smoke and fire.
  Flywoo AIO BF4.4.3 ESC question husafreak 4 159 03-Feb-2024, 03:32 AM
Last Post: husafreak
  Help FC wiring to different ESC brand cele_FPV 2 143 30-Jan-2024, 10:29 PM
Last Post: cele_FPV
  FC to ESC wiring diagram Help oddjobsguy 4 909 01-Oct-2023, 03:30 AM
Last Post: oddjobsguy
  After flashing the ESC using JESC zomer 1 170 18-Sep-2023, 09:50 AM
Last Post: voodoo614
  Tmotor Pacer single sided f7 fc and velox 650A esc failure Pumpkin head 3 228 26-Aug-2023, 05:41 PM
