Sinopine FPV Micro AIO Camera with Clover Antenna
Mini 5.8Ghz 40CH 200mW FPV Transmitter Raceband 600TVL FPV Micro AIO Camera with Clover Antenna for FPV Camera System $10-15/set. Does anyone in this forum can make a review for it?
Features:
1. Super small and lightweight
2. Good quality image
3. 4-leaf antenna for better signal transmission
4. Button control
5. Easy to install,plug and play
6. Power by 1S lipo battery
Specification :
1. Output power: 200mW
2. Input power: 3.2–5V
3. Current consumption:3.2V-5V,500mA(type)
4. Camera resolution: 600TVL
5. Video system:NTSC
6. Mini illumination: 1 lux
7. Field of view: 120°viewing angle
8. Antenna dimensions: 22mm X 29mm diameter
9. Antenna: 4 lobe right hand circular polarized
10. Frequency: 5.8GHz 5 bands 40 channels, with Raceband: 5658-5917MHz
11. Size: 18.7*13mm(L*W)
12. Weight: 4.8g
Is there some reason you are specifically interested in Sinopine products? Any reason you seem to be only looking at Ali?
(19-Jun-2017, 07:02 AM)Tom BD Bad Wrote: Is there some reason you are specifically interested in Sinopine products? Any reason you seem to be only looking at Ali?
In other words, is this an offer to give out one of these cams? Smile
Big Grin No, forrest was asking about a Sinopine VTX the other day also from ali, I suggested going with one from eachine on BG, no response to suggestions...?
Without even receiving a free one to review, I'll tell you a few things that don't make sense with this little AIO camera/VTX:
1. At the distance you'll be flying anything you'd fit this camera to, a CP antenna is a waste of weight. The first time you crash, you'll bend the lobes of the antenna and send the SWR through the roof. This will make the already hot video transmitter circuitry burn out in record time as bending things back into shape by eye won't restore even the bad impedance match that the antenna had in the first place.
2. That seven segment LED display is much thicker and heavier than a few strips of 0402 sized SMD LEDs on the PCB.
3. Why 200mW? Again, you're not going to be flying anything with this over long distances. 50mW or 100mW would be better for the life of the transmitter and for overall flight time. Half an Ampere of current on top of what the motors will pull from the poor 1S battery!
The best antenna you can get for these little cameras is a linear balun dipole with a u.fl/IPEX connector that makes it easy to replace the antenna without having to poke a 75W plumber's soldering iron into the board and wonder why the PCB tracks end up on the end of your iron.
Smile
  • Tom BD Bad, Drone0fPrey
  FPV CAM for Cinematic Footage Kepnik 0 115 11-Mar-2024, 10:01 AM
Last Post: Kepnik
  airplane camera vitalii.airfly 0 739 11-Nov-2023, 04:41 PM
Last Post: vitalii.airfly
Photo New Product First Dual-Lens Action Camera in The World powerman668 0 309 07-Nov-2023, 08:00 AM
Last Post: powerman668
  New Product RunCam Thumb Pro Camera (4K) SnowLeopardFPV 36 10,303 07-Jul-2023, 12:14 AM
Last Post: aeterfpv
Video Lights.. Camera.. (DJI) Action! davejavu 14 1,284 31-May-2023, 11:26 PM
Last Post: mstc
