Threads: 15
Likes Received: 1 in 1 posts
5 Good question.
SimonK bootloader let's you flash both FW.
Check the manual to see if they are programable through the signal wire.
If not, there's no school like the old school
Threads: 2
Likes Received: 0 in 0 posts
0 When I got them if I remember correctly, I did update them with the USB linker to enable comp and oneshot, but I can't remember if it has the SimonK bootloader.
The manual doesn't even discuss those ESCs, so who knows.
I mean it flies fine, it's just that part of me that wants to update since updating is the thing to do in this hobby...
Threads: 2
0 I wonder if I leave the +/- wires soldered to the PDB, and plug the battery into the quad, could I just desolder the signal wire and plug that into the USB linker. I could disconnect the servo plugs from the Naze also.
Hmmmmm how much stuff would I blow up.
Threads: 15
5 The negative needs to be conected to whatever you are flashing with.
Signal needs a reference to ground.
Threads: 2
0 Worked great. Used my USB linker and had to desolder signal and negative, but it didn't take that long.
PROBLEM!!
This is what they're doing now after calibration on Cleanflight. What have I done???
Threads: 15
5 That chirping happens after calibration.
Check the post I put on my previous comment.
It's related to min command setting.
Calibrate, then see what motor does not chirp. Then in blheli check the values for that motor for min command and max comand. Copy that to the others.
Threads: 15
5 You have no clue my friend, it's like the motors know what you want to do before you do it. Lol
Happy flying!
Threads: 2
0 Seems like it!
Thanks for your help!
