Threads: 1
Likes Received: 0 in 0 posts
0 Hi guys, 3 days ago i lost my drone in a tree and i couldnt find it. Today i decided to go search for it and found it. I test flew it without my goggles and seemed to fly fine. Then i went home and i tested it with my goggles and something was wrong. I am only 50 cm away from the drone and when i look at it with my goggles i have good image but when i look up i just see snow and when i look at it i have image. By the way my osd the bars that tells you how good the signal is , it tells me 0.
Threads: 586
Likes Received: 8,962 in 6,632 posts
Likes Given: 1,425
787 Make sure you haven't inadvertently switched the VTX into pit mode. Also make sure the goggles are on the exact same band/channel frequency as the VTX is broadcasting on. Manually tune your goggles to the same band/channel. Don't use the auto-scan feature as that often locks onto the wrong frequency, and even if it's only a few MHz off that make quite a bit of difference.
Threads: 1
0 Hey, No im not using the auto scan feature i have set up betaflight so that i am on a specific band/changnel. Also how do i check if the VTX is switched into pit mode?
Threads: 1
0 I believe that i have the RUSH TANK Racing
Threads: 586
Likes Given: 1,425
787 Pressing and holding the PWR button on the RUSH TANK Racing VTX switches pit mode on or off, so try doing that to see if that changes anything.
Threads: 1
0 i've tried that it didnt change anything
Threads: 1
0 Guys Please someone help me
Threads: 125
Likes Given: 99
388 09-May-2021, 10:48 PM (This post was last modified: 09-May-2021, 10:49 PM by voodoo614.) VTX could have been damaged when it was turned on and sitting there for probably 10 mins or more. When the motor is not spin, it can take the other electronics a long time to drain the battery.
