Signal not getting to motors?
Hey guys, I just finished my first actual build and I'm having an issue. My TX signal is getting to the Naze32 Rev 6 Acro (Confirmed within Cleanflight "Receiver" tab), but I cannot get the motors to spin, when connected or disconnected to the PC. I did make sure ARM MODE is on via the switch, but still nothing. The motors do stun when I use the motors have a use the sliders to test them out.
I used the wiring method below. Let me know what over info you need.
I/m using the SBuss wiring, but NOT the OSD wiring.
TX - RadioLink AT9
RX - RadioLink X9D
FC - Naze32 Rev 6 Acro
BODY / PDB - ZMR250 (official)
[Image: pdbnaze32-1.jpg]
Thanks!
sounds it's not arming!
first of all, are you using betaflight? if so... with 2Khz mode, if you running too many things on the Naze32 it won't let you arm... try to disable ACC or go back to 1Khz
secondly, could you try to calibrate ACC if you have it enabled?
Also make sure your throttle goes below min check. If you don't have the throttle range of 1000-2000, you can trim the at9 in the menu under "end points". I had to trim mine pretty far to get the right values.
Thanks guys. Ill check when I get back to the house.
OSCAR - I flashed BetaFlight, but am using cleanflight interface because changes made in headlight do not save when I change screens. Yes I do not save, lol. I have not adjusted anything with a KHz mode (that I know of). Calibrating the Accelerator was one of the first things I did.
Bangkok- I'll check all that asap. Thanks
OK, Looks like Minimum Throttle is set to 1150, and Receiver shows 1073. I adjusted the END-POINT and got it down to an even 1000.
After typing that last sentence I went to see if the "max throttle" was affected, and when I moved the throttle stick up, the motors spun up and scared the CRAP out of me! lol.
Looks like I'm good to go. THANKS GUYS!!
Now I just have to figure out why the FC made an audible "BEEP BEEP" and then the ESC on motor #1 blew. Or So I'm assuming as that motor will no longer spin up or make noise when the system starts up. Good thing i like tinkering. lol
Hey, here's to hoping for a simple fix! If it makes u feel better I fried a minimosd and an openlog within a day Wink Sad Doesn't make me better admitting that...
I always assume the most complicated problem and forget the simplest fix hehe, thanks guys!
Crazy how that happens! 80% of my FPV problems have an easy solution that isn't always obvious haha!
  Build Flyfish Atlas 4 with P1604 motors mstc 10 271 Today, 07:11 AM
Last Post: mstc
  Discussion Which size motors for 3.5" octo ??? BigBeard 8 435 26-Oct-2023, 09:41 AM
Last Post: romangpro
  Build What motors for 4" power quad? romangpro 30 2,359 21-Sep-2023, 02:26 AM
  Help Holybro ESC/motors stop spinning after about 10 seconds cpintheloop 7 988 23-Feb-2022, 01:04 AM
Last Post: cpintheloop
  How often are you replacing your mini quad motors hinakuras 1 598 09-Jan-2022, 12:18 PM
Last Post: kafie1980
