Shuriken x1 props -- less speed is OK
Oscar did a great review of the Shuriken X1 200mm race quad.   I ordered one.    I'd like to order some durable replacement props that tame down the speed some.   From what I can tell it ships with 5x4 tri-blades.
Reviews say it's very fast and has powerful motors.   It's probably faster than my abilities at the moment.   So I'm hoping to choose props that gain efficiency and flight time.  I don't care about top end speed yet.
I read Oscar's "How to choose motor and propeller for Quadcopter" article which is very helpful.
From what I can tell in the article I should decrease the pitch from the stock 5x4.  I did find some 5x3 tri-blades available.
But should I switch from a 3 blade to a 2 blade prop instead?
Some of the quad specs are:
- T-MOTOR 2305 2600KV motors
- Compact size and 200mm diagonal length for 5 inch propellers
- Input voltage: 7 - 42V
- Filtered voltage output 5.2V 2A
- Weight: 343g ( excluding battery )
I'd like to get durable props --possibly DAL or King Kongs for now.
Thank you.
I don't think 5040 propellers are too much worse than 5030 props (2 blades)
If you want to gain efficiency, probably stick with 2 blades, 3 blades are normally less efficient.
Thanks Oscar.
The Shuriken has shipped and will be flying soon.
  Discussion Props Gyr 1 93 01-Apr-2024, 11:03 PM
  Budget 1503-4000kv motors : 5" props on 1S? : $25 RTF drone? mstc 0 355 04-Dec-2023, 01:22 AM
Last Post: mstc
  Review Damn 5 inch T-props MomoBrut 2 205 31-Aug-2023, 03:26 PM
Last Post: MomoBrut
  Two blade props on Mob6 19000kV motors? swequad 9 405 31-Jul-2023, 10:25 AM
  Foxeer "Donut" Props - SAY NO! BadRaven 4 283 20-Jun-2023, 09:52 PM
Last Post: Lemonyleprosy
