10-Jul-2017, 02:00 AM
Hi all,
Over the weekend I finished building my second quad (a clone of my first build to act as a backup). The original quad is built with the exact same components and can run 3S and 4S fine. But the new quad constantly rebooted itself when using 4S.
Before I go too far into detail, I have found and fixed the issue! but I was looking for advise on if what I did to fix the issue is correct or there is a better way to do it.
The problem was the flight controller which is a Omnibus F4 from banggood, the 5v regulator was being overloaded when using 4S and the board was rebooting. On my original build I had the full voltage of the battery running to the vbat pin and besides the OSD and receiver, nothing else was being powered from the FC.
To fix the issue I ran 5v from my PDB to the vbat pin on the FC, this of course caused me to lose correct voltage info in my OSD, so I ran a wire from the VCC pin on my PDB to the vbat pin on my runcam swift 2 and am using its OSD to display my voltage.
My question is, should i be running my FC off 5v through the vbat pin (which still goes through its own 5v regulator), or should i remove the 5v regulator from the board and run the 5v to one of the 5v motor pins to power the board. Essentially my FC is being powered through 2x regulators... is this an issue? And if not should I update my original build to the same to reduce stress on that regulator?
Thanks! and let me know if you need more info.
